projectSHO89
As stated above Fords older PCM software had recorded a false emissions failure for the catcon. They had revised updates for the PCM.
A quick and easy way to see if the converter is plugged is to see if the outlet is colder than the inlet. If it is then it is plugged. Or you can go to a Ford dealer and see if their is an update for the PCM.
The "PCM update" was only applicable to 98s.
Steve
