Re: http://contour.org/mods/mods.php?s=howto&displayid=43
I'm wanting to attempt this later today, but am a bit curious about some particular details.
The vacuum line... Does anyone know the exact dimensions required? Would I find sometime like this at Home Depot? Also, given that I'll be pouring solvents through it, will normal clear plastic tubing work? I don't want the tube to dissolve in my hands!
Also, will there be suction on the plastic tubing which will pull the cleaner into the engine?
