SVT Doood
I just installed a new starter...
I have continuity from the battery + to the little bolt on the solenoid.
I have continuity from the battery + to the large bolt on the solenoid.
I have continuity from the battery - to the ground on the MTX, and to the firwall.
Will not crank over.
I tried to jumper a cable from the battery to the small bolt to energize the solenoid and spin the starter (therefore bypassing the starting circit)...no go.
I tried a jumper a cable from the battery to the large bolt to energize the solenoid and spin the starter (therefore bypassing the starting circit)...no go.
I'm reading 12.4 volts on the battery
I'm reading 12volts volts from the battery - to the small bolt on the solenoid with the key turned to start.
I'm reading 8 volts from the battery - to the large bolt on the solenoid.
EDIT: Just took the battery in for a test...it was o-k.
I need some help here..
