Hi guys, it looks like there are some pros on here when it comes to this transmission.
My issue I'm having with ours is when the car is cold it runs fine, but as I drive the car for about 5 minutes the transmission starts making a high pitch whining noise (changes tones with shifts) and starts slipping. The slipping gets worse as you drive it to the point where it will not engage in any gear. Let the car cool down, it drives again temporarily until doing the same thing.
My gut tells me this is internal and I might as well just replace the transmission, however I'm looking for any knowledge that I may be missing before I do that. I have replaced the fluid (drain and 4 quarts) and I've replaced the speed sensor.
Could this possibly be the range sensor?
Any thoughts are appreciated. Thanks!
