TRicker
it wont go. i turned the self adjuster all the way in, but the piston still needs to go 1/2" into the caliper. it wont move at all. the ebrake will force the piston out, but it wont take it back in. the brakes on this side may have been dragging because they wore the pads down to the metal when there was 1/4" of pad left on the other side. i tried a clamp on the piston to push it in but i cant get it to push in. i took off the reservoir cap and tried to loosen the bleeder to see if i could bleed off any pressure and push it in. it wont go in. i'm assuming now that it's frozen. any suggestions from the allmighty CEG?
