SicSE
First off, please don't post retarded sh*t like this. It's just retarded.Come on guys lets get some good responses....
All this tells me that you had an ignition problem before. You said the old plugs were fine, but if they were the wrong heat range, or if a plug wire didn't have a really good connection, putting in new plugs will get these kind of results.well a small update im now getinng 12.5 more miles to the Quarter tankon the .45 gap and more as i should say i dont go past the avarage 5600 when im shifting but the throtal response is quite different (better) shiftin smother too
If you were to regap your current plugs to factory spec, I bet you would see further improvements.
I would think it more likely to be the other way around, given a properly running engine.so basicly the closer gap uses less gas?
