DuratecDave
Found that the upper transmission mount bolt?? is broken. The one below the airbox.
I've searched & found these can/do break, but need advice on repairing.
Assume I will need to tap or convince the broken part out of the mount. Replace it with "all-thread"? If anyone has the specifics, I'd appreciate it. The missing/broken half is gone, so no idea of its overall length, nuts, number of washers & their sizes, etc. Is there another rubber isolator at the bottom? Haynes manual lacks a decent photo & google search not much better.
Have searched & read that metric grade 8.8 (for this application) is recommended over grade 10.9? Is there a Ford 'repair kit' available, should I replace the rubber isolator, etc. I assume the transaxle is resting on the cradle, but the car is not/has not been driven in some time. Anyone got a good used spare for sale? Stock/OEM works best.
I've not worked on a MTX75 before. Do I jack the transmission up a little, insert the mount and install the nut in the small gap between the transmission and the mount? Does the rubber compress any? Your help is appreciated.
BTW, the red stuff is the last of Ford's brittle wiring insulation....
