SVTbuckeye11
Hi guys, like the title says, overnight my brake pedal went from a normal 'biting' position, to going to the floor today. The reservoir was low but not empty. I cant see any leaks coming form the calipers or any bad brake lines. The only other place i think the fluid could be going is the booster. I'm curious if anyone has had a similar issue or more experience with it.
I'm about to bleed the brakes so see if it changes anything.
Thanks
Thanks
