crewchiefpro
My boost control is a cheap, spring loaded design. The engine will go to 15 lbs of boost when all hell breaks loose, then it will drop to 8 lbs. If I let it coast for a second then go back to full throttle it will jump to 15 and then do the same thing. It is hard to watch because the car is accelerating so hard but I am quite sure once it realizes the boost is too high it stops the boost at 8. Sure it is still fun but not as fun as 15 lbs. I am wondering if the problem may be in the waste gate instead.
I may have to go the way CSVT#49 and get a digital boost controller, however I needed to know if anyone has any luck with another brand or changing the waste gate spring before I make the switch.
