Ares
So after my steering rack went bad, I dropped the subframe, replaced the rack, got new control arms, new drivers side axle, new seal, drained rest of the trans fluid and refilled with new fluid.
I put everything back together, feeling pretty good about myself because there's no leaks. Steering feels great, everythings lined up. But I put it into gear and the trans starts slipping a bit in reverse and first.
Now I'm not sure what the f to do. Is this thing toast or what? Is there anything I can do? Should I drive it around more to see if it goes away?
