First I had to replace connector C371 (8 gauge red and 12 gauge green) because it melted. The new connector melted so I just used spade terminals to replace it. Well, now instead of melting at the connector it melted the 30 amp fuse into the box (fuse 37 I think) and smoke rolled up from under the dash. I'm about to just wire in a relay to bypass the fuse box for the blower but I'm worried that might cause a fire since after I fixed the connector it just melted the fuse. Has anyone else had this issue? I noticed many of the connectors at the junkyard had burnt wires and melted connectors as well so maybe this is something with a TSB out. It is something that should have been a recall. I'll have to replace the fuse box when I get home but only if anyone knows why it does this and can be fixed. I'm not sure if the resistor is the issue (although I only notice issue when running wide open and that wouldn't be the resistor) or if the blower is drawing more current then it should. The blower seems to be running at the speed it should run so maybe this is just Ford under-designing something again.
