KAOS_3.0
so anybody who's been reading my posts knows I've had a slight leak from my MTX pretty much since I swapped it in. well I did a quick google search to see how much a input shaft seal would cost, and found a thread in a focus forum about a guy with a similar problem, and the advice he got was this:
which induced a facepalm moment as I remembered swapping the slave cylinder from my old MTX into the new one because the one on the new one was siezed, and didn't know about using any sealant at all at the time...:blackeye:
so what I'm asking, is if this advice applies to the V6 MTX bellhousing or not, and also if not, what the part number is for a front seal on this thing.
also, while I'm in there, I plan to replace "the bolt" with a much harder unit, kept in place by a little JBweld as opposed to loctite. what I'm wondering here is whether the trans has to come apart or not to change the shift turret. I don't think it does, but I was taking the old trans apart when I removed the one I have for a spare, and honestly it was a long time ago and I can't remember much of the process...
if the seal issue turns out to be solved by anaerobic sealant, I intend to also open up the case just to take a look at what my diff looks like and also to take some pics of my output shaft so I can start gathering parts for the final drive swap...
thanks for the input guys, trying to get all these details sorted and purchased before monday so I can do my clutch from monday to wednesday. thanks again
Other than worn out axle seals (which is most common) the trans could also be leaking between the clutch slave cylinder and bellhousing. That causes trans fluid to drip down the inside of the bell and out that little rectangular hole at the very bottom of the bell. Usually caused by not using the proper anerobic sealant when installing the slave cylinder. Been there, done that.
