Ok, my shifter was super sloppy and grinding in second and 3rd. fixed the bushing and tried some adjustment to the cable that controls big black think on transmission. That fixed most of the sloppy shifter feel and 2nd is now golden but third will grind unless I go into third at about 1600 to 1800 rpm. My shifter does seem to have up and down play while in gears but side to side is really good.
Do you think this is bad syncros or more adjustment?
Now since driving 100 miles the car seems to run pretty good, has some great power.
I had my cpu flashed with a sct chip. The guy that did the chip added 2 different maps and i have been going back and forth. I have some codes to report and to search on. I will clear codes and drive 100 miles and report what comes up on each two settings.
Here are the codes i have now
P1151 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1401 DPFE? dont know what this one is
P0172 System too Rich (Bank 1)
also P0175 from time to time
After another 50 miles I have had some surging at coasting speeds. Also, when cruising around 50-60 car sometimes dies when I come to a stop like it cant catch its idle. Last thing as of now, is at low rpm when I press the gas the lights get a little brighter and as car idles low lights dim just a bit
After some looking and messing with stuff I have noticed that I will get all the codes on both chip settings and with the chip off of car I get 1401 right away
I'm assuming its a vacuum leak somewhere or leaky injector possibly because of the bad gas mileage
