Manimillion
Well, after a long pause, here is an update on the progress of my svt.
As you can see, the new dash bar is already put in and now the car has the steering column and steering wheel back in place.
Had the seat fitted today, so that the seat tubes can be welded in.
All gussets are welded in
Rear plexiglass window marked and frame for it is all done. Just needs to be drilled, sealed and bolted on.
Rear firewall frame is done, just needs the carbon fiber panels to be made and fitted on.
Here is a shot showing the beautiful cage work done by my friend. Only thing left is the seat to be all bolted in and then the harness bars can be welded into the X bar.
