For Sale '98 csvt #3102 red/mnb please buy this svt!
111R
Los Angeles
THE CAR AS IT STANDS:
1998 CONTOUR SVT E0 3102 with 117,864 miles
ABOUT 7K MILES SINCE SWAP;NEW PARTS INSTALLED LESS THEN 10K AGO.
NO DYNO TIME ON ENGINE/TRANS/CLUTCH; ONLY DATA LOGS. NEVER RACED OR ABUSED. TRANS BROKEN
IN FOR 1000 MILES ALONG WITH CLUTCH.
Engine:
* 2006 Ford Escape 3L ~29k miles (only used Mobile 1 since swap; 6 qts.)
* Nautilus Performance Lower Intake Split-to-Oval Port Conversion
* Nautilus Performance Fuel Rail Block w/ New FMC FPR
* SVT Upper Intake Manifold
* 19# Injectors (ORANGE SVT)
* Lightened and reduced-size Power Steering and Underdrive pulleys (Red)
* New FMC plugs and FMC wires.
* All new rubber coolant hoses
* New Waterpump/Serpentine belt
* New A/C compressor & condenser
Intake:
* Stock intake tube/filter
* P.R.T. optimized TB (63mm)
Air/Fuel and Tuning:
* Walbro 255 LPH Fuel Pump.
* SCT X-Calibrator 2 PCM programmer
* Innovate Wideband (not installed properly)
* Nautilus Performance Group performance tune (91 OCT, NO SECONDARIES, DOWN-STREAM'S OFF)
Transmission:
* Livinsvt (Brett Powell) built transmission
* Focus Shift tower
* Improved/newest shift forks (FMC)
* NEW SVT Clutch
* New SVT flywheel
* Torsen T2 Limited-slip Torque Biasing Differential (FMC)
* B&M Short-throw Shifter
* P.R.T. Urethane-filled (type 94A - stiff) Transmission Roll Mounts
* All new bearings (FMC)
* All new seals (FMC)
* New TOB/Master/Slave cylinders (FMC)
* New Hoses
* New Half Shafts
* New shifter bushings
* RP Synchromesh MTF
Suspension Upgrades:
* Koni sport shocks/springs
* SPC camber kit w/ beefy (custom) camber plates (able to adjust camber for front)
* HPP RSTB (uni-bolt; easily removed)
* sub frame connectors painted black welded on
* tubular toe control arms powder coated black; rear (Redcoat Raceworks)
* spherical end-links rear (Redcoat Raceworks)
* Custom adjustable sway bar end links front
* B.A.T. reinforced sub frame
* B.A.T. 21MM sway bar w/ poly bushings
* NEW CONTROL ARMS
* NEW KNUCKLES/HUBS
* NEW WHEEL BEARINGS (ALL 4)
Brakes:
* Mintex pads front/rear
* drilled/slotted rear rotors
Aesthetics/other:
* Recaro SRD seat w/ 5th belt
* Momo shift knob Air Race
* Carbon Fiber trunk (CF1.COM)
* Carbon Fiber hood (CF1.COM; hood pins from hoodpins.com)
* fog lamp delete
* Windshield washer delete (never needed it in California)
Audio/Electrical:
* VDO gauges in custom bezel; {oil temp, oil pressure, boost, WB}
* Pioneer AVIC-N1 w/ voice Head Unit (2 DVDs; 2 software versions)
* MB quart reference speakers front; Eclipse speakers rear
* Optima red-top sealed battery
* Moroso battery relocation kit in trunk (passenger side)
THE STORY:
This car was bought in April 2002 at 38K miles at a small dealer outside Boston. The car has been very reliable and economical car to drive. I love driving this car very much, but after some long hard contemplation, I have decided to part with it. I need money for graduate school, so, the car should go to a owner who can enjoy and appreciate this SVT as much as I do. The modifications this car has was done only with new parts (mostly Motorcraft parts), and with the expectation that the modifications would be a upgrade, in addition to being discreet. This car had not been modified until about 90k, or about 5-6 years ago. This car was once turbocharged with a aftermarket (Nautilus Performance Group) kit that was enjoyed tremendously on the previous 2.5L engine. With this knowledge, it has the drivers side fender cut-out in order to facilitate a cold-air induction system for the turbo. Obviously there is nothING there now, but if this car was to be turbocharged or had a true cold-air induction system, it would be easily installed. All modifications where done with new parts, and all invoices associated with
parts and installation are saved in a 4" binder; along with an additional 4" binder that contains all other invoices, service papers, every oil change slip, and documentation. This car has ALWAYS achieved 20+MPG, regardless of which engine combo was used while using the A/C. This car has A/C that works VERY well-- a must in Los Angeles; it should since it's all new! The car has FLAWLESS tire ware, considering the LASER alignment the car receives consistently and the additional camber adjustment that was added to the car. New transmission parts, suspension control arms, a/c components, sway bars, bushings, sub frame, knuckles, bearings, and tires all installed less then 10,000 miles ago (tires have less then 2000, clutch has less then 500 miles). Every single component maintained on this car was done professionally and with documentation. With the exception of the welded sub frame connectors, this car COULD be reverted to stock if a new owners chooses to do so.
FLAWS:
There are some flaws with this car; it has failed CA smog twice but NOT because of sniffer or visual test but diagnostic test (PCM) failure. It has CEL's on intermittently with codes P1000, P1100, P0171, P0173 IIRC. It struggles when you floor the vehicle, but seems to have a lot of power and torque. The car has been looked at by a absurd amount of mechanics, multiple smog technicians, ford guru's, tuners, and there has been no consensus on how to fix this car. The paint has several flaws including dents, scratches, and normal wear. The antenna mast was replaced because it was broken, but it was replaced with another antenna with a broken mast that goes up half way (have working mast in A box). The trunk mechanism does not work on the key less remote, BUT it does function from the cabin and the key on the exterior. The axillary gauges do not function with the exception of the oil pressure. The wideband was installed by a authorized Innovate distributor that installed it incorrectly and fried the sensor; gauge works, but no sensor. Boost is not there because there is no turbocharger, and oil temperature sender is installed on a different oil pan (see parts list below) that had a turbo oil drain; simply installing the pan would make the gauge function. The car was involved in two accidents within two blocks of my home (on both occasions) while sitting stopped at a traffic light. On both occasions I was rear-ended and was compensated by my insurance company with a
new rear painted bumper (I have documentation from my insurance company that proves neither were my fault). The car is regularly driven. The car is driven and started and exercised at least once a week.
INCLUDED:
The SVT PLUS the list of parts below that I have collected that is associated with the car; I would like for them to go IN THIS SALE. The stock trunk and hood are included, although they come with their own flaws since I have moved them around from garage to garage. ALL documents, service records, copies of pictures, data logs, all tune configurations, all instruction/shop/service documents, 3 sets of keys (1 accessory, 2 keys w/ remotes; one brand new) included.
THE PARTS (I HOPE this is all accurate current):
COND MILES
06 ESCAPE UIM USED 29K
FIAMM HORNS (2 PAIRS) NEW
K & N FILTER USED 15K
PLUMBING/COOLING HOSE ESCAPE USED 29K
MAIN ENGINE HARNESS ESCAPE USED 29K
ESCAPE ENGINE MOUNT USED 29K
ESCAPE MISC. TENSONERS USED 29K
MISC. ESCAPE WIRES/WIRING/IDLER PULLIES/PARTS USED 29K
MODIFIED ESCAPE FUEL RAIL (SHORTER) USED 29K
E0 SVT FUEL RAIL USED 111K
SVT MOTORCRAFT SERPENTINE BELT NEW
SVT MOTORCRAFT WATER PUMP BELT NEW
BOSCH 02 SENSOR (X2) #13115 NEW
SMALL WATERPUMP SVT HOSE NEW
WHITE BOOST GUAGE V.D.O. NEW
PRECISION 42# INJECTORS (X6) USED 3K
ESCAPE INJECTORS (X6) USED 29K
CLEVITE ROD BEARINGS (X6) NEW
I.A.T. SENSOR MOTORCRAFT NEW
FORD SVT WHEEL BEARINGS FRONT (X2) NEW
06 ESCAPE PCV VALVE NEW
MOTORCRAFT TUBE ASY - TRANS (XS8Z-7T504-AH) NEW
BOTTLE TOUCH-UP PAINT MOTORCRAFT 19500-6758A USED 5 YEARS +
MOTORCRAFT SPARK PLUGS (X6) NEW
T-STATE GASKET (R.O.L.) NEW
Weapon R Stainless Steel headers + NEW Y-PIPE USED 20k
SANDWICH ADAPTER - OIL COOLER NEW
8 RANDOM EARL'S BRAND HOSE FITTINGS NEW
SILICONE ADAPTERS/CLAMPS FOR LIGHTNING 90MM MAF NEW
BROKEN TRANS COVER F0RD NEW/BROKEN
MOTORCRAFT CLUTCH MASTER CYLINDER NEW
MOTORCRAFT IGNITION WIRES (SET OF 6) NEW
BATTERY TRAY SVT USED
MOTORCRAFT COIL PACK NEW
SVT ENGINE (BLOCK, HEADS, LIM) USED 111K
BROKEN A/C CONDENSOR USED 111K
03 ESCAPE OIL PAN W/ OIL TEMP SENDER & TURBO DRAIN USED 15K
CONTOUR DRIVER SIDE HEADLAMP USED/BROKEN 90K
INTERIOR/FLOOR TRIM SECTION; SMALL MNB USED
FORD TRANS TUBE (97BZ-7A512-AD) NEW
SVT MNB REAR SEATS/BENCH + HARDWARE USED 95K
SVT EO CENTER WHEEL CAPS (X8) USED 100K
SVT WIRES, CERPENTINE BELT, MISC USED 95K
REAR SWAY BAR BUSHINGS (TORN) USED/BROKEN
SVT COOLANT CROSSOVER TUBE USED 100K
ESCAPE LIM (X2) USED 29K
SVT A/C COMPRESSOR USED/BROKEN 111K
SVT WATER PUMP USED 25K?
SVT E0 PS/ALT PULLIES USED 95K
FELPRO FULL GASKET SET ESCAPE NEW
AUX. OIL COOLERS EARL'S BRAND BLK (X2) NEW
SVT 2.5L OIL PAN N/A USED 96K
SVT REAR SUBFRAME USED 112K
SVT PRECATS (BANK 1 & 2) USED 96K
EARL'S BRAND BRAIDED COOLER LINES- 6' (X2) NEW
SVT HOOD & TRUNK USED 90K
SVT JACKPOINT COVERS UNPAINTED (X4) NEW
SVT MTX-75 STOCK DIFERENTIAL USED 65K
SVT TAPE PLAYER E0 USED
USED SVT KNUCKLES FRONT USED 115K
06 ESCAPE VALVE COVERS (PAIR) USED 29K
06 ESCAPE TIMING COVERS (PAIR) USED 29K
90MM LIGHTNING MAF NEW
RANDOM WHITE BOX W/ VDO T'S/JUNK NEW/USED
PUROLATOR AIR FILTER NEW
TIAL TURBO BLANKET USED 15K
FRONT SPLASH GUARDS (PAIR) USED
WILWOOD 6 PISTON BBK W/ F/R BRAIDED LINES NEW
SVT FLYWHEEL USED 111K
SVT CLUTCH USED 111K
SVT FRONT CONTROL ARMS (PAIR) USED 111K
SVT HUB SPINDLES USED 111K
SVT FLOOR MAT SET USED
RANDOM MOTORCRAFT SCREWS/PLUGS NEW
CONTOUR V6 FLEX PIPE NEW
TRUBENDZ CATBACK MAGNAFLOW SYSTEM 2.5"SS USED 200 miles?
RANDOM BOX OF •••• USED
CD'S OF MULTIPLE TUNE COMBOS USED
SCT XCAL2 USED
CUSTOM MADE ALUMINUM KONI KNOB (SHORTER) USED
SVT REAR 19MM SWAYBAR REPAINTED BLACK USED 112K
SVT FENDER SNORKLE USED 96K
4 ADDITIONAL SVT E0 WHEELS W/ BFG RUBBER USED
4 E1 wheels no tires USED 90K
SVT E1 SVTTOUR MODIFIED MAIN WIRING HARNESS + INJECTOR HRS NEW/USED
MIL Eliminators (NPG) NEW
THIS CAR IS NOT BEING PARTED OUT, I AM NOT SEPARATING THE PARTS; THIS IS A PACKAGE DEAL.
PRICE = $1 OR BEST OFFER!
CONSIDERING THE CAR IS NOT PERFECT, AND I HAVE A GARAGE FULL OF PARTS, I HAVE NO IDEA THE VALUE OF THE ENTIRE LOT! EMAIL ME IF YOU WANT THIS CAR AND THE PARTS AND MAKE ME AN OFFER; PLEASE INCLUDE YOUR NAME AND HOW I CAN GET IN TOUCH WITH YOU. IF MY INBOX IS FULL, PLEASE POST ON THE FORUM.
THANKS
CLASSIFIEDS RULES
Last Updated: 7/20/22
