striker2
Official CEG Vendor
current mods consist of cool air intake, 2.5in custom bent exhaust, aeromotive adjustable fuel pressure regulator set to 40psi, FR wires, MSD coil pack.
	Need to fix that A/F.:help:current mods consist of cool air intake, 2.5in custom bent exhaust, aeromotive adjustable fuel pressure regulator set to 40psi, FR wires, MSD coil pack.
Definitely a tuning issue.What type of fuel were you running? Premium unleaded would smooth out the graph a bit more.
what gives?
Did you reset the PCM? If not, I wonder if there is something funky with that FPR.
Where was the oxygen sensor when you were on the dyno? Tailpipe? If so, that can read lean when you're fine.
