This is the result of several months of work, and for a first test I'm pretty happy.
Got 187whp and 159 tq on a Mustang Dyno at 200ft above sea level, 71 degrees ambient and 70% humidity.
This is a 98 SVT engine in a 95 SE being controlled by an OBDI EECIV system.
All sensors/servos new this year. ECT and IAC are 1995 version everything else is later model. Secondaries are vacuum controlled. Compression about 180psi and consistent. All wiring replaced with good used wiring this year.
Mods are:
-Open filter w/heat shield
-ProM MAF calibrated for 19# inj
-Optimized and knife edged throttle and secondary butterflys
-Slight port matching
-Iridium plugs
Gutted-Pre Cats
Trubendz Y pipe w/cat and Magnoflow resonated catback
Superchip for 95 SEV6....rev limit at 7500 and premium fuel required.
Recent maintenance included complete cleaning of UIM/LIM and intake valves.
This is running a bit rich at the top, possibly due to the SE computer assuming 17# inj? Also some pinging, so I may be getting some timing retard.
Mods are:
-Iridium plugs
Gutted-Pre Cats
