Optimizing A 65mm Throttle Body
Items:1.Hack saw
2.Screw driver
3.Dremel—Cutting disks
4.Thread locker (blue or red)
5. Steel Bar ½ x 1/8th
6. 1996-2004 mustang GT throttle body (crown vics work but it has a different linkage)
Here i have written a walk through on how to modify a stock mustang gt throttle body to fit a svt 2.5L application.
Time: 2-3 hours. (Based on skill and tools that are available to you)
Now the first thing we need to do is remove the TPS if one is installed. Follow this link for the how-to.
http://www.contour.org/ceg-vb/showthread.php?t=50388
Now looking at your throttle body, the first thing we need to do is remove the screws that hold the plate and bracket in place.
1. Now you’re going to take your Dremel with cutting disks and grind down the flattened screws sticking out the back throttle body shaft. So it should look like this.
We do this because it makes it much easier to remove the screws due to the crimped threads. Most people skip this step and try to remove the screws, resulting with stripped screws. Leaving them having to drill them out. Once both screws have been cut down continue to the next step.
2. Now you’re going to flip the throttle body over. Press firmly with a correct size screw driver bit and twist. If your tip feels loose or too big, try to find one that best fits because you might strip the screw.
3. Once you removed both screws it should look like this.
4.Now holding the throttle body with one hand, twist the linkage so the throttle body goes WOT. (Wide Open Throttle).Once you do that, stick your hand into the housing and pull forward the plate.
5.Once you pull the plate out, your throttle body should look like this.
6. Next step we are going to pull out the linkage. MAKE SURE YOU REMOVED YOUR TPS ALREADY!!
