BurritaSVT
As we all been aware we did have a new engine swap added to Contour/Cougar community. The COP is used on the newer 05 engine and will be easier to find in the future with lower miles once the escape engine are mostly higher mileage.
COP
pros:
*minus the spark plug wires
*cleaner engine bay to some
*will be offered in the future for low mileage
*still easy to install like the Escape full swap
cons:
*coil pack configured in series will drop low voltage on high rpm or parrelled will overload the pcm drivers and damage pc or coils
*still have to rewire the harness using patch work (really need a standalone coil driver to support the driver loads)
*pay more for the motor even double
*still have to modify the egr
*still have to modify the TB
*availablity low at this point
*no HP gain from the orginal 3 liter since no mods except expensive coil packs to replace
**still need to modify the fuel system (return Style Only)
*needs tune CEL
Full 3 liter swap
pros:
*less expensive
*easy to install
*readily available for $500
*great for ATX cars
Cons:
*modify the EGR
*modify the TB
*still need to modify the fuel system (return style only)
*needs tune CEL
3 Liter hybrid:
Pros:
*price is low based on labor too
*labor cut in half with LIM Mod (loose Secondaires not needed)
*direct swap no modifying
*no tune needed
*any mechanic could swap it too even you
*no fuel rail modification
Cons:
*without LIM Mod cutting and grinding (High Labor)
Now for dyno results that were provided by Buckeye he already shared
Now as you noticed this is the original dyno now we all saw the dyno he shown us where he said it ran quicker on the dyno when he shifted the dyno 1.7 sec earlier where the car started later at same RPMS.
Now here is the real layover after you line up the 5250rpm crossover point we all know does not lie.
Now look at how the hybrid has more torque down low ........then maintains that line till the 3800 rpm IMRC opens and still nevers drop below the troque curve of the so called torque monster he claimed makes it the best. It finally tips the hybrid torque for only 500 rpms wow that is a short torque curve there. Of course you notice the torque is 40wtq over the COP at 6500 rpms. Now all the BS he spreading and worst off he was trashing me and tom months back on our site you can see for yourself and comes here to call us out. Well the proof on the dyno never lies but I will be darn if he will lie to all the ceg's & neco about the data he shifted to make his setup seem superior. You can obviousily see the hyrbid accelerated in time at the same rate and even faster once you compare the time they actually started the pull.
I just can't see this guy BS everyone and then bashing our products and if I ever made something that was hurting performance I would hit the drawing boards again for something better.
Thanks Joey
COP
pros:
cons:
*needs tune CEL
Full 3 liter swap
pros:
*less expensive
*easy to install
*great for ATX cars
Cons:
*modify the EGR
*modify the TB
*needs tune CEL
3 Liter hybrid:
Pros:
*no tune needed
Cons:
Thanks Joey
