kscontourkid
the car is a early 99 contour SE sport v6 mtx. Done some searching but no one has all my symptoms. the car will not start. total silence when the key is turned. the story is this... car sat out for a week without a battery while parts were swapped to new engine. engine harness was removed from car with engine. everything is back in car and all connections are hooked up. checked voltage through engine i have power all over the engine. starter,mega fuse...etc when the key is turned like i said there is total silence. i have all accessories working. the fuel pump does not prime and there is no relay click for the starter... nothing. the PATS light does nothing as well. it blinks slowly as normal in accessory but when turned to run the light turns off. tryed all my keys (have 3) and none work. even tried a non-chipped key to see if i could get the PATS light to flash rappidly. Nothing. called ford and they said the computer should not throw out the keys just from sitting and want to do a $100 diagnostic before new keys are coded. if anymore information is needed please ask. I am at a total loss to this issue.
Thanks
Thanks
