BurritaSVT
you meant 8.5:1 right? because you will have to run race gas if so. Joey
The only "bad" boost things I've read here with a built block are the 2.5L heads lifting (3 instances, if I recall) at 23psi. Actually.. I'm thinking one of those instances was Joey's on a 3L. If you're going to do it up right, you might want to put larger studs in (if there's enough material) and also o-ring it.
I never found a copper gasket for sale, though I did find a company that would make one... using an existing gasket as a template.
They were built motors with low compression pistons. One of them was Keyser's old setup that TheFordGuy had.Hmmm... I was planning on running ARP bolts on the heads and mains... but if that isn't going to be enough for 18psi then maybe I should start investigating larger studs...
Although with 2.5L heads your compression ratio is going to be through the roof unless these people were running 7.5:1 or 8:1 pistons...
