CSVT#49
Alright guys I've done some searching and I've seen mixed results. On my 05 Escape 3L I didn't see a knock sensor, or rather I don't remember seeing a knock sensor. I guess that's what happens when you try to think back 3 years. I looked at online auto parts stores and it is of a different design so I'm pretty sure it wouldn't work anyway. In any case on the 2.5L the knock sensor is located on the rear side of the block just in front of the trans. The 05 3L block does not have a threaded hole for the knock sensor at that position. What I could do is thread in an adapter to the smaller hole that is not used in the back, but the knock sensor at that point may not see enough of the surface for a good reading depending on the adapter.
Thoughts?
Thoughts?
