BurritaSVT
I am finishing up the engine for a customer and we will be testing the 2004 cams with the SVT upper intake with the LIM mod with NPG cold-air system with gutted cats with my own custom y-pipe with catless only Res. We will run the setup stock tune with stock airbox then add a tune then we will switch out to NPG cold-air . The dyno will show all the gains with the setups then we will swap over to the oval port LIM and UIM to see if the power falls off like we suspect due to the resonance frequency of the ports and smaller ports. We will run the stock tune on that setup then cold air then tune and compare all the dynos
Here is the engine going in the customers' car for dynoing.
