3.0L sable
can the mount from a 04 escape 3L be used in place of the 98 mount if the bolt sizes are different
maybe i worded that wrong , can the 04 escape mount be used on the 04 escape block and bolt into the 98 car? sorry i was at work and i had to hurry
Yes you can use the 04 escape mount in your 98 contour. The difference in the mounts only affects what engines it can mount on and not what car it goes in.
Rick
i found out i have the older mount since mine has a build date of 97 so i have to order the cougar mount and bolts. thanks for the help.
