For Sale or Trade 2000 3.0 Turbo Cougar For Sale in VA - $4500
jnuke25
Well I bought this in early Nov. from Daniel car has been pretty good to me thus far. Had a few issues; replaced the starter on Christmas day, new rear struts, in the process of replacing all the worm clamps with t clamps (had a two clamps fail on the highway), replaced the sunroof (now fully closes but is still not working right) and I also rerouted some fuel lines that sat right under the down pipe. As of right now I am tracking down some type of fuel issue I will know for sure once I get a new walbro and get it installed. This car is a DD on 8psi and is a blast to drive. I am selling it buy something 4-door trying for a baby this year so mine is gonna be the on thats gotta go. I am also up for trades or trades/cash so just let me know, I am also willing to help to meet somewhere I will travel up to 3 hours from my zip code 23228 (Richmond) or these two zip codes in PA 15501 (Somerset) and 15201 (Pittsburgh).
Exterior - The exterior is in good shape, not paint issues, no big dents or dings. There may be one or two small dings that I have not noticed. Rims and tires are in great shape, plenty of life left on the tires. Could use some Z-rated tire but I believe the are H-rated right now can check if needed.
Interior - It tan leather seats driver side has some small tears all other are in great shape. At some point I believe the car had matching tan trim/headliner however was painted black (not me). There are some trim pieces that have broken clips (drivers side over window and courtesy light needs replace) these issues may or may not corrected. The entire instrument panel has been switched to 01-02 so the odometer is not the proper reading. Has around 137k on body.
Engine/turbo -
2005 ford taurus engnie swap
-xcal3
-Analog Input Cable
-AEM wideband A/F gauge
-oil pressure gauge
-volt gauge
-boost gauge
-NP fuel rail mod
-walbro 255 fuel pump swap
-stage 3+ racing clutch
-42lbs Precision injectors
-90mm maf
-46mm Precision wastegate
-Synapse Synchronic Blow Off Valve
-60-3 masterpower turbo
-msd header with v-bands going to the y pipe
-custom y-pipe 2.25in pipe form manifolds into a 2.5in to the turbo
-custom 3in down pipe with 2x 70 degrees bends not the hard 90degree bends
- y-pipe and down pipe are heat wraped
- all exhaust clamps are v-band
-custom full 3in racing exhaust all the way out
-2.25in fmic pipe
-1000cfm 12x36x3in fmic
and FYI I have already taken care of the fuel issue, must of had a loose line in the tank, I pulled it earlier in the week and reinstalled everything has taken care of the problem!!!!
at this point i'm not to sure just kind of seeing what anyone has, so just let me know
Gonna let it go for $4000 if someone picks it up locally without me driving anywhere, just to throw that out there.
Still open to trades!!!!!
Lock it up if you would. Straight up trade for a 02 Escape XLT with a local guy!!!!!
CLASSIFIEDS RULES
Last Updated: 7/20/22
