jeffersbmw
- Joined
- Apr 11, 2010
- Messages
- 28
This is a 1999 SVT Contour. It has 135000 miles on it. Black exterior. I was building the car for Rally America but I have decided to move in another direction.
The car has been stripped on the inside and a very sturdy cage installed. 1.75 x .095 tubing all tig welded with gussets on all x's.
Here are all the new parts installed with in the last 2 months, 4 new toyo 225 50 16 tires, kyb GR2 struts all 4, springs front and rear,tie rod ends,control arms with bushings and ball joints,4 wheel alignment,lf axle, front and rear pads and rotors tured, lr cailiper, bosch plugs,air filter, fuel filter,water pump belt,oil changed,rain x wipers, sway bar end links.I have recipets for everything
battery relocated to the rr of the trunk with a kill switch.
corbeau racing seat and rci harness
The prev owner installed customer true dual exhaust with flowmasters, it sounds good but has small exhaust leak,car also has small vibration under acceleration. I believe it is the rf axle. 69 for a new one. Also 3rd gear grinds under hard accel, blocker ring i assume.
The cage alone is worth about $4000. Id like to get $3000 for it.
It could be used for autocross,track days,solo, 24 hr lemons rally what ever you want really.
314-560-1640 car is in stl
pics can be seen here. I can email more if needed
http://stlouis.craigslist.org/cto/2433179534.html
