Here are some of the part numbers for aftermarket and/or Ford OEM 3L parts.
If anyone has any corrections or things to add to this post, please do so.
Please keep other comments and/or questions in other threads please so that this post is just as informational as it can be.
If you have part numbers, please post them here - 3L build related parts only.
Note: Prices listed are what have been paid in the past and may not be current with today's pricing at your local parts store.
Engine:
Per Bill Jenkins:
3.0L short block, NEW. Build date is from 04/01/03 and is the same part# for Sable, Taurus, Escape.
4F1Z-6009-BA List $702.55 Inet $526.91 Core $500.00
Seals and gaskets:
- Fel-Pro Part# 61006 SE TB gasket, $1.59
- Fel-Pro Part# 61006 SVT TB Gasket
- Fel-Pro Part# 70149 EGR gasket
- Fel-Pro Part# 9038PT 2.5L Left Hand Head Gasket
- Fel-Pro Part# 9039PT 2.5L Right Hand Head Gasket
- Fel-Pro Part# 9540PT 3L Left Hand Head Gasket
- Fel-Pro Part# 9541PT 3L Right Hand Head Gasket
- Fel-Pro Part# CS9038 2.5L lower conversion Kit (includes oil pan gasket, oil seals etc.), $72
- Fel-Pro Part# ES72159 Head bolt set, 2.5L 2 req., $16.92ea
- Fel-Pro Part# HS9038PT Head gasket set, conversional $231.15
- Fel-Pro Part# MS92586 3L Plastic Oval Port Intake Manifold Set
- Fel-Pro Part# MS95715 Exhaust Manifold Gasket (53mm x 32mm)
- Fel-Pro Part# MS95726 Intake manifold gasket set, $30.15
- Fel-Pro Part# OS30675R Oil pan set , $35.27
- Fel-Pro Part# SS72873-1 Valve Stem Seals (Viton)
- Fel-Pro Part# TCS45966 Camshaft rear seal gasket set, $6.95
- Fel-Pro Part# TCS45967 Crankshaft front seal, $14.55
(Includes 2.5L head gaskets that are not needed.)
- Fel-Pro Part# VS50462 Valve cover set, $32.59
- BCA part# 3909 Crankshaft oil seal, $13.32
- BCA part# 5277 Crankshaft oil seal (teflon), $16.76
- BCA part# 99363 Crankshaft oil seal (redi-sleeve), $33.50
- BCA part# 88187 Harmonic balancer sleeve, $4.18
- BCA part# 482041N Oil seal, front timing cover, $7.67
- BCA part# 99187 Oil seal, front timing cover (redi-sleeve), $22.58
- Spectra Premium #1719 non-SVT radiator, $138.41
Clevite 77 bearings:
- CB-1772P Rod bearing, available in standard, -.25MM, -.50MM, and -.75MM.
- MS-2207 Mains (not yet available)
Federal Mogul:
- 7262M- Standard Grade Main bearings (also available in non standard grade)
- 6-4395A- standard grade rod bearings (also available in non standard grade)
Ford part numbers:
- 2S7Z-6513-AA ST220 Valve Springs (measured 161-163 lb/in)
- 3F1Z-6564-AA New Roller Finger Followers
- 3M4Z-6675-BA Upgraded Oil Pan Set
(2 drain back channels and better lower baffles – comes with gasket and hardware)
- 4F1Z-6065-AA Head Bolts
- F3LY-6214-A Connecting Rod Bolts, need 12
- F5AZ-6700-A 3.0 Front Crankshaft Seal
- F5AZ-6701-A 3.0 Rear Crankshaft Seal
- F5DZ-9E936-AE SVT TB Gasket
- F5RZ-2A411-A 2.5L UIM Plastic Retainer Grommet with Brass Insert Sleeve
- F5RZ-2L181-AA 2.5L UIM Plastic Retainer Grommet
- F5RZ-6020-A 2.5 Right Front Timing Cover Gasket
- F5RZ-6020-B 2.5 Center Front Timing Cover Gasket
- F5RZ-6020-C 2.5 Left Front Timing Cover Gasket
- F5RZ-6345-C Lower cylinder block retaining bolts, need 4
- F5RZ-6345-D need 8
- F5RZ-6345-E need 5
- F5RZ-6584-B 2.5 Right Valve Cover Gasket
- F5RZ-6584-C 2.5 Left Valve Cover Gasket
- F5RZ-9439-B 2.5 Lower Intake Manifold Gasket
- F5RZ-9H486-BA 2.5 Upper Intake Manifold Gasket
- F5RZ-17285-AA MTX-75 Speedo Gear
- F6DZ-6345-CA need 5
- F6DZ6505A Valve-exhaust
- F6DZ6507A Valve-intake
- F6RZ-9K313-BC Fuel vapor hose
- F7RZ-4211-AC Differential Bearings (2 req)
- W701-512-S301 TTY Crank Pulley Bolt
- XF1Z-6051-BA 3.0 Right Head Gasket
- XF1Z-6051-DA 3.0 Left Head Gasket
- XS4Z-7201-CD Upgraded Shifter Tower (03+)
- XS8Z-7230-DD 1-2 Shifter Fork, Roller Bearings (02+)
- XW4Z-9448-AA Duratec Exhaust Manifold Gasket (50mm x 26mm)
- YF1Z-6148-BA Piston rings, $30.03 (does 2 pistons)
- YF1Z-6513-FA Duratec Valve Springs (rated 153 lb/in per manual)
- YL8Z-6622-BA 01+ Upgraded Oil Pickup (req 01+ main studs)
- YL8Z-6687-AA 01+ Upgraded Windage Tray (req 01+ main studs)
- YS2Z-7230-BA 5-R Shifter Fork, Revised (00)
- YS4Z-7230-AD 3-4 Shifter Fork, Modified Oil Scraper (01+)
- YS4Z-7K453-FA Shifter Retaining Clip
Motor mount/Powersteering bracket parts
(needed for mid '98 and previous years to fit to the 3L block):
1S7Z3A732AA Bracket, $32.72
W704693S309 Long Bolts, $5.22 each
W704694S309 Short Bolts, $3.53 each
ARP bolts:
- 253-4701 ARP Head Studs
- 253-5402 ARP Main stud kit
K&N Filters:
K&N Filters
Tapered Conical - DB x DT x L
RF-1045 (5.5 x 4 x 8) = 720cfm
RC-4630 (5.5 x 4.5 x 6.5) = 615cfm
RE-0950 (6 x 4.625 x 6) = 605cfm
RE-0920 (6 x 4.625 x 9) = 900cfm
RU-3530 (5.375 x 4.375 x 7) = 645cfm (3.75" flange)
Straight Conical - D x L
RU-1785 (5 x 8.5) = 800cfm
Miscellaneous parts:
- Stant Part# 13396 160 Degree T-Stat
- Bosch# 13246 L1H1 Wideband O2 Sensor
Tools:
Rotunda Tool Set - Essential
T94P-6136-AH Connecting Rod Guides
T94P-6256-AH Camshaft Seal Protector
T94P-6256-BH Camshaft Seal Replacer
T94P-6256-DH Camshaft Damper Replacer
T94P-6312-AH Water Pump Pulley Remover/Replacer
T94P-6312-BH Water Inlet Tube Replacer
T94P-6510-BH Valve Guide Replacer Adapter
T94P-6510-CH Valve Stem Seal Replacer
T94P-6256-CH Camshaft Alignment Triming Tool
T94P-6510-AH Valve Stem Seal Remover
T94P-6510-DH Valve Guide Replacer Adapter
T94P-6565-AH Valve Spring Compressor Adapter
T94P-4451-AH Measuring Fixture
T94P-4451-BH Differential Shim Selection Tool Adapter
T94P-7025-BH Multi-Bearing Cup Replacer
T94P-7025-CH Differential Drive Shaft Seal Replacer
T94P-7025-DH Selector Shaft Bearing Remover/Replacer
T94P-7025-EH Pinion Spline Socket
T94P-7025-FH Gear Lever Aligning Tool
T94P-7025-GH Differential Bearing Cone Replacer
T94P-7025-HH Selector Shaft Seal Remover/Replacer
T94P-2100-AH Sub Frame Alignment Pin Set
T94P-6000-AH Power Train Alignment Gauge Set
T94P-70010-AH Transmission Range Sensor Tool
Engine:
Per Bill Jenkins:
Seals and gaskets:
Federal Mogul:
Ford part numbers:
ARP bolts:
K&N Filters:
K&N Filters
Tools:
