.... from coated headers thread ( http://www.contour.org/ceg-vb/showthread.php?75580-Coated-vs-non-coated-headers )
i think the only difference between the mondeo and the contour up front is the 5mph bumper.
have you got any photo's of this location plan ?
how about laying the oil cooler flat and directing air thru it and out under the car. The forward movement of the car should encourage air to be drawn down under the car from the engine bay. I've seen this done with WRC cars for the water radiator (searching for pictures) .... G.
I can't speak for Gorman, but on CSVT's, the lower bumper slot is considerably wider than the radiator, each side of the bumper slot has a plastic diverter to direct air from the sides of the slot to the center where the radiator resides. I plan to remove one or both of these diverters and install small flat plate oil coolers behind the slots. The idea here is to have the oil coolers in clean air, and not have them dropping their heat load into the radiator airstream. In the summer, I've seen oil temps go way beyond 250F on the highway pulling my Aluminum utility trailer, there's just too much heat being dumped into the (water) cooling system, and I don't like to see the water temps at 230 or 240F for sustained periods.
I've had plenty of experience with the small Modine-style oil/water heat exchangers that Ford uses, and they're plenty adequate for 200HP, but beyond that, or for long-term high-load situations, they just get heat saturated and you need something that can reject more heat from the oil..
