BurritaSVT
Ok I will be finishing up the pulley system tomorrow and making the mount then I will ship off the materials back to my machinist to reproduce the plates out of solid aluminum and have the pulley made for us. We have some idler pulleys we are adding to the setup one up top by the SC pulley is why you see the plate up so high and we are making an arm with another one around the smaller pulley that drives the SC. We are able to use a large 5" pulley for the main serptine belt we are calculating the SC to turn 8000 rpm to 10000 rpm at first. Then we will build the setup where if you want to raise the boost you just replace the outer pulley at the dual pulley setup by unbolting it, The final version will have 2-3 bolts fastening the two pulley together so before you ask the pulley are just in position not functional at all. Joey
