LOUDSHO92
As some of you may know we have a test set of Stage 1 SVT cams (they are an upgrade over the SVT cams) we need a tester for them. We would prefer someone with a 3.0L Hybrid and all bolt on if possible, but if you have tuning ability and all of the bolt ons that would work as well. The cams are for the will work only with secondaries, no oval ports.
Once these cams are tested and work, we will move to the oval port cams then.
The expected gains are around 15hp.
What we want: Tester to install the cams in their Contour, provide before and after dyno, and cores for grinding on. Also a deposit.
What you get: Cams for free.
If you are interested post or PM and we will work things out. Thanks.
 Why wouldn't they work with the oval port heads?  Is it because you're using the SVT Timing gear?  If thats the case... big deal, people swap the 2.5L SVT Cams into 3L oval ports all the time.
