one day you will regret it i imagine
of course you'll gain a few ponies by deleting it.
Sounds like you have a slow leak and need some freon with leak stopper.ok then, i guess ill keep it cuz i do have sticky leather seats.lol
but im not accually know what the problem is with it. i turn it on, and the clutch engages for about 3 second, and then turns off, and repeats. so while driving, the car jerks forward when it turns off and dies when it turns on. andone who if that is a sign of a bad compressor
noo, i filled her up with some, and it thats not the problem.. its allready at the correct pressure.
soo i dont kno what it is..
i just pulled the ac relay for now so i can use the defroster without the car bucking..
any other ideas?
I am running with the no a/c belt on until I can afford to have the compressor (and associated bits) replaced. There was a noticeable increase in power when I bypassed the a/c, but it may have been because the bearings were on the way out. The compressor completely seized and ended up snapping the original belt.nope, totally not worth removing it. If theres a problem with the clutch or anything like that, you can always put in a non-a/c belt and leave the whole a/c assembly in place.
its quite a pain to remove all that junk and its really not all that heavy [like MAYBE 20 pounds]. you'll likely get slightly better cooling with the a/c radiator removed.
Freon? Are you 1995?
BINGO!your not going to gain anything. the a/c pulley just free wheels when it isn't on and it shuts off when you go to wot anyway ....
I agree you will have more trouble selling the car without a/c if you ever do.
Actually Freon is a Dupont trade name. However it is also generically used for any type of pressurized refrigerant using fluorocarbons. (i.e "R" number 12, 21, 22, 134A, et cetera...)Freon? Are you 1995?
these cars are almost to the point of not worth reselling. there are other areas of gain outside of performance. i removed the complete system in my car.
1)car runs cooler w/out the condensor in the way of the radiator
2)allows you to install a oil pressure gauge in the proper location much easier
3)omp strut bar fits better w/out the hard line by the booster being in the way
4)you can pull your fan from the top w/out jacking the car up
5)engine bay looks cleaner and less clutered
