elraido
I kant speel
Car is running fine but it won't go forward or backward while in any gear. Speedo will climb up as I go up in RPM's but car does not move forward. Any ideas as to what has happened? Axel? Shift Cable?
hmmm. if ur speedo is going up, then it isnt the shift cables. if its the axles, u should hear some noises from that direction.
drivers side axel appears to be broken. Boot is slightly twisted on itself and you can shake the axel around. :laugh: Crap. Pud told me to drive it properly. LOL Just to make sure there isn't something else, when I have it in 1st I can take my foot off the clutch, not touch the gas and it won't die....is that normal for a broken axle?
I am searching around, but I can't seem to find anything on replacing them.
sounds like broken axle(s), the diff is spinning, which registers the speed, but no movement, i would bet on snapped axle(s).
HOw hard to change out? I have the ford cd, but do I need any special tools? Cost of a new axle?
anyone have a parts number on this thing?
Edit. called ford, they said the part has been discontinued. WTF?
Easy to replace as well. Basic tools needed only. Unless you can't get the axle out of the tranny, then you might need one of those slider thing-a-ma-jingers
I don't think Ford sells the entire axle anymore, last time I checked they did sell it piece by piece though.
I would look into a Napa axle (supposed to be better than OEM), if you're trying to find one locally. It's not too bad of a project to pull an axle. You will lose some tranny fluid on the driver side axle unless you drain it first. Make sure you don't damage the axle seal in the tranny![]()
I just called them, they said they can get one for me tomorrow but I can't get the core charge since it is snapped. Total $166.02 :blackeye:
Oh yeah, what procautions should take to not damage the seal?
And what is Steves number at Tousley?
Just make sure you push the axle in straight and carefully. 651-484-8888
Pretty sure that'd be more than $160 though.
