SicSE
I have a timing chain wedge designed for the Triton engines that pushes back the timing chain tensioner and holds the chain in place so that you can pull the cam without having to take off the front cover. I'm hoping to be able to do this with the Duratec when I swap rocker arms. So has anyone pulled the cams leaving the front cover on? Also, does anyone have pics of the timing chain area with only the valve cover removed?
