ok, I have my heads and valves all cleaned up now.  Used a small wire wheel on a dremmel to speed up cleaning the ports in the heads, the secondaries were really nasty.  I then used a combination of brushes and Berryman's B-12 to get the ports completely clean.  Used Berryman's B-9 Chem-Dip on the valves, worked pretty good but the exhaust valve didn't come all that clean so I used a brass wire wheel on a bench grinder and cleaned the valves all up.  I have before and after pictures at home and will post them later.  My question is...
I am planning to start re-assembling the heads, putting the new valve seals in, putting the valves back in as well as the valve springs/retainers/keepers, today. Is there anything I should do to anything before reinstalling everything? I assume I should put a light coat of oil on the valve stems as I put them into the valve guides? Then just re-assembly everything in reverse of removal?
When I put the heads back onto the block, should I coat the cylinder walls will anything? When I first removed the heads I wiped some oil on the cylinder walls but that didn't seem to work very well so I wiped them down with WD-40 and that seems to have worked fine to keep rust off there.
I've also stoned the bottom of the heads as well as the block to ensure I have all gasket material and anything else off.
I don't need to do anything to make sure the valve seat fine with the head right? I have everything marked as to where they came from so each valve/valve spring/retainer/keeper will be put back into the exact spot it came from.
Any other tips or things I should be doing? Just want to make sure I'm not missing something and want to make sure the car runs smoothly after being put all back together.
