KAOS_3.0
what 3l oil pan doesn't work? I'm using the taurus pan, it's deeper and better baffled than the 2.5
the 2.5 pan actually has the windage tray below the fill level for the oil, no good. the 3l pans are deep enough to get the oil below the tray. with the taurus pan you have to drill two holes. not hard. use a small drill bit in the center of the hole on the block to get a mark to drill on the trans. then pull the trans and drill the hole out with the appropriate bit. not hard.
some guys even leave those bolts out.
