Or possibly your sat radio or radar detector are messed up...? Also a little bit of advice for you, a fuse rating is there for a reason... not to protect the components being plugged so much as the wiring powering those components. A fuse rating is there because that's what the wire can handle... put a bigger fuse in, wire gets hotter, which can potentially lead to melting and fire.... so always replace your fuses with a fuse that's meant for it... The fuse is a safety, it blows so your wiring doesn't fry, which means you need to check the wiring and the components hooked to that wiring. (usually a local car install shop will give you fuses if you ask for them, probably cheaper than buying them from a store, or you could go to a junk yard and just start pulling fuses left and right)
I would start by un plugging everything and testing the wires with a multimeter, test the cig plug and see if you have continuity, if you do it means the wires are pinched or shorted out, if not, and the fuse didn't blow when you put it in (with nothing plugged into the cig socket)..... it may mean one of your components is messing up... If that's the possible case, put them in someone elses car and see if their fuse blows, may help to make sure they have a 15amp cig socket as well, otherwise you may not be able to recreate the issue...
