contoursvt11
Be Gentle I'm New Here
I have had two of BAT's camber kits fail on my '98 svt. They have ~30k +/- 5k miles on them. What heppens is that through normal wear and tear the elliptical disk that is welded on top of the metal bearing housing shears off and the strut rod then destroys the metal housing, rendering the suspension useless and unstable. I ordered a replacement kit for one side and it was the same construction as the fist two I had. When the other side failed I called BAT and asked about it.
They said that they have had a bunch of people call in about that failure happening, most of them had the groud control coil over kits. I currently have Koni adjustables and H&R springs. I have not been tracking or autocrossing the car, just normal street driving.
BAT said they have an outside manufacture make the camber kits for them, and they provided me with Spec products contact info. I contacted them and they were very friendly. The sent me a return sticker for the broken kit and and sent me a new one at no cost. After they received my broken kit the engineers determined that they kit was a rip off of their kits. So I am shinning light on this situation for the contour group. The kit the sent me is far better. It has both superior construction as well as materials that are used. The kit is $112.60 and the part number is #89675. The manufacture's contact info is:
4045 Specialty Place
Longmont, CO 80504
www.specprod.com
I am not sure if BAT is aware they are selling cheap rip off kits, but if they are it is not only shady but dangerous. Just my $0.02.
Longmont, CO 80504
www.specprod.com
