Alright so I made some decent progress once I settled down after some help from a few fellow CEGers.  I still have to pull the radiator and fans (any tricks to it, it's being a pain in my a$$), find the rest of the connectors I need to disconnect, hook up the cheery picker but I'm getting there should be able to have it out by late afternoon tommorow.  Thanks or hte help today fellas.
Tricks for the radiator....
First, wire up the A/C condensor to the frame to keep it in place when you drop the radiator. Then push up on the radiator and have someone push 2 8 penny nails through the top guides of the radiator so that it will rest on the frame up top. Then pull the 4 bolts for the lower radiator mounts (2 8mm on each mount). Then pull the 2 8 mm bolts (one on each side) that keep the Condensor attached to the radiator (Condensor should stay in place if you wired it up like I said). I assume you already disconnected the hoses (passenger side top and bottom and drivers side top). If you have an SVT radiator, the fan shroud must be removed from the radiator. In the middle height area of the radiator, there are two 10mm nuts that can be loosed or removed to slide the fan shroud off the radiator. Don't forget about the plug from the shroud into the A/C compressor, the ground on top passengers side of the fan shroud on the frame, the plug into the top of the A/C dryer and the two plugs on the top middle part of the fan shroud. Then slide the fan shroud out. Then push up on the radiator and have a buddy pull the two 8 penny nails and sneak the radiator down and out. You will then need to make sure the car is fairly high up in the front so that the radiator can sneak out. Don't forget to remove the plastic air deflectors from the side of the radiator/condensor.
And a hint for the A/C compressor.... when you remove the serpentine belt and when you remove the the 3 long 8 or 10 mm bolts that hold it on the engine block, just slide it back so it sits on the front passengers side of the subframe and use some mechanics wire to hold it on the subframe so that you don't have to disconnect the A/C lines from the A/C compressor. It does have enough flex in the lines to slide over and sit on the subframe and it is plenty far enough out of the way to pull the engine. I have never read the ford CD, so I have no clue if that is the way it tells you to do it. It that may not be a hint, but more so info to inform if you haven't read that.
As for pulling the half shafts, I know you got it, but you didn't need to loose the top strut mount bolt or any of that garbage. All you need to do is pull the sway bar endlinks, pop out the tie rods, and then pry down with a long bar or a long 2x2 peice of wood which is what I use to get the ball joint out. It is stupid to use a picklefork and own the ball joints when you don't need to. And there is no need at all to loosen the LCA bolts like one said. The LCA's will flex enough to get the ball joint out and with the sway bar endlinks and tie rods out, the whole front corner will just swing out of the way enough to let the LCA back up and there is plenty of play to then pop out the halfshafts.
PM me with any questions.
Reebs
