hotdimmes
Anyone done it? Is it possible? I can only see one removable bolt, but still leaves it stuck on the inside hinge.
Would make my custom dye job a little easier if I can get it off. That's what she said.
When I replaced my rear seat backs I swapped the armrest because the old one was in better shape. From what I remember there is a torx head bolt as part of the pivot on the side that is exposed when the narrower seat is folded down. Even once the bolt is out I still had to spread the bracket since you cannot remove the pin on the other side that corresponds to the bolt removed.
