mjwood0
Well, luckily I have a little spare cash right now so I'm trying to get my vehicles back in top condition before winter and finances get tight.  I just got an oil change, ATX flush and fill and new front tires so things are starting to look up!  The following are my list of things to fix.  Just want to run it by the good folks here to determine if I'm on the right track.
Problem 1
In the last couple days, I've noticed a definitive whine coming from the drivers side of the engine compartment. It sounds kinda like the moose, but that's never happened when it wasn't cold. Also, I notice that my throttle seems to be hanging worse then ever. Finally, blipping the throttle doesn't make the noise go away. This normally cured my moosing...
I'm going to try to do the throttle hang fix to try to take care of the moosing anyway (last winter it was really annoying) but I want to make sure I'm not missing the real problem. I'm also going to clean the IAC as it probably needs it.
Problem 2
When driving on the freeway and I pass someone (revving up to around 6000 RPM or so), my check engine light will come on. It stays on for a minute or so and then goes away.
This is a 95 SE so it has the OBD-I system. Checking the codes reveals a 111 -- all normal. What could this be?
I was thinking of changing out the spark plugs and wires to possibly fix any misfire issues. What plugs / wires have worked good in these cars?
Problem 3
I just got two new front tires and had them mounted and balanced. I have noticed a chopping noise coming from my drivers side front tire. Could this just be a bad job of balancing, or could this be alignment issues?
Thanks for any help. I don't want to throw money at problems unless necessary, but I want to get things fixed up so I don't have to worry about them.
			Problem 1
Problem 2
Problem 3
