98 E0 SVT with '97 build date
~70K miles=Bought vehicle second owner (EXCELLENT Cond.)
~75K miles=Replaced radiator fluid and Trans Fluid
~80K miles=Replaced air filter (K&N)
~85K miles=Replaced water pump due to failure (plastic upgrade)
~87K miles=Plugs and Wires (Taylor and NGK Iridiums)
~90K miles=Replaced clutch (Spec Stage 3)
~100K miles=Replaced all fluids again (Switched brake fluid to Gunk high boiling point fluid)
~105K miles=Replaced pads and rotors
~105K miles=Removed main catalytic convertor and added MIL
~151K miles=Spun Rod Bearing. Replaced with 3L Hybrid (Buckshot Block)
Replaced all timing equipment, guides, lifters, Valve Springs (ST220), All gaskets, oil pump, pick-up tube, windage tray, pan, and most sensors.
Cleaned MAF, EGR, UIM/LIM cleaning, Injector O-Rings replaced, LIM Linkage replaced with Custom pieces.
Added B&G 1.6" drop springs, Quaife LSD, New Shifter Forks, Cables,
Speedo Gear, Shift Tower, Resurfaced SVT Flywheel (Lightened).
~153K miles=Totalled car...sigh....Rebuilt entire front end using front clip/core support from donor car, replaced bumper bar, headlight mounting panel, radiator, fan assembly, front fenders, hood (CF1 Cowl), AAS front bumper, ST200 Wheels, LCA's (four-bolt), Axles, Ball joints, Knuckle assemblies, Rotors (Again...), Roll resistors (front with E.S. inserts), Removed ALL A/C Components, Removed Resonator, Replaced windshield.
I think that's about it. Finally ran in the 13's...once.
