To me it sounds like the non-oxygenated stuff is for "off road use only" for whatever reason. Maybe it puts out more emissions or something.
They have non-tax diesel in Montana that is only for "off road use only" with a purple dye in it that is for farmer's. If they pull you over and stick a tube down your tank and it comes out purple, you get in a ton of trouble. Maybe it's got some sort of dye like that?
And oh man, where do I start with these guys! :shrug:
SVT Contours are not boosted, but the compression ratio is high enough (10:1, btw) for Ford to warrant the use of ONLY premium fuel. Sure, you can get away with 87, but the high compression of the engine can ignite lower octane fuels before the spark even goes off. This means that the fuel is burning before the intake valve is closed, which, if you can imagine, isn't the best for the engine.
There is a knock sensor, but it's not as "giving" sort of say as my Sentra, which "recommends" premium fuel. The Sentra's knock sensor is very senstive in conjunction with ECU programming which allows running on 85/87 octane.
I don't think they put that programming in the SVT Contour, which is one reason why it says "PREMIUM FUEL ONLY" on the guage, manual, and fuel door. There's a reason why it says that, and other cars have "Premium Fuel Recommended" maybe in only one or two of those places.
onder:
I would definitely just use premium fuel than to do this :help:
Right-o!
