myconsvt
ok, well i am planning on dueing a 3.0 turbo. but i have a problem with turbo set ups could anyone help me out with how to run the wastegate, and bov. and were would be the best way to get the car tuned?
			have you done enough research on turbos to know how everything operates?
myconsvt, I think that you have a lot of research to do before you try to take up a project like this. There have only been a couple known custom turbos on contours and the builders obviously have the fabrication skills required and the brains to do it. The waste gate is a device that vents exhaust gasses either back to the down pipe or they're just dumped into the atmosphere to keep the boost levels at their desired ranges. The waste gate needs to be positioned somewhere close to the the turbo to prevent boost creep. Again, without a kit, this is going to be extremely difficult to do without the required welding skills or you're going to need quite a bit of money for labor to get it done. The BOV is normally positioned close to the throttle body to prevent back pressure from messing up your turbo. You need a vaccum line running from the BOV so it knows when to vent. I think you need to do a lot of research and maybe you need to reevaluate your abilities to do this project because the task is not easy. Good luck with the build.
well i know that i have the abilities to do the project since my old job was a welder, on semi's. and my job for the past 3 years has been a tech @ southfield chrysler jeep. plus in high school i placed 3rd in a welding comp that was held for all local vocational schools. i just need the help with the wastegate routeing i did some research on it and i have a good idea now.
