trubendz? had to remove heatshield?? what now?
yamaha racer 686
lancaster PA
ok so to get my trubendz exhaust to fit properly i had to remove the heat shield. now my ebrake and center console feel like they are on fire which i know is becuase of removing the heat shield. Now is there anything i could do to cut down on the heat. Would header wrap work? or modifying the heat shield??
you may have to bend the heatshield but no remove it. same thing happened when i optimized my y pipe. however i welded the heatshield back on.
just take it off and beat it flat. when you go to put it back on the bolts will pull it against the hump. or you also could just beat it around the hump maybe a little more space if you do it that way.
