I'm wondering as to what would be the best setup for my svtc. I'm always replacing the things that need to be replaced when i buy a new car, so what would be the best plug and wire combos out there. Nothing but the best for my svtc
			Just stay away from "+4" snake oil.. split fire, all those gimmicks are a waste.
Bosch +4, and split fire plugs don't last 40% of the time a standard copper (or better yet: a double platinum[which is spec'd on the car]) will.
Stick to OEM Motorcraft, or the Autolite APP764 (Double Platinum) as long as you aren't Forced Induced. Gap to spec (0.052-0.056) and DO NOT BELIEVE "pre-gapped" for a second.
Amen, I wouldn't put a Bosch or Splitfire plug in my car for love or money. In the Taurus SHO, some aftermarket plugs were too long, causing the boots to fit improperly, and sand and water, etc. could make its way into the plug well. I also believe I heard some stories of piston collision. May not be as much of a concern in the SVT, but stick with Ford parts and you'll be all good.
there is absolutely nothing wrong with autolite double plats. they are basically the same thing as motorcraft
I put Autolite dbl Plats in my '95 Mystique and they are crap. As it was mentioned about a year ago using anything but Motorcraft is a crap shoot. And that is correct in my case.
