I noticed before I put the car away for the winter that two of the spark plug tubes had a small amount of oil in them . So I decided it's time to do a little project or maybe big lol . When I get it out in the spring I'm bringing it to my friends shop to use his lift . I'll be doing the valve cover gaskets and tube seals , new plugs and wires . I have been holding on to a brand new motorcraft water pump and since just about everything under the hood is 23 years old it's time to replace all the hoses and the pump. Replace the belts ( they have been done before ) new battery ( 7 years on current one ) and a oil change plus tranny fluid drain and fill . Should be good as new after . The spark plug tube will be the first leak ever after 23 years to happen , only thing to date that crapped out on the motor was a cam sensor that's it so I have been lucky . Look forward to digging in and saying some swears no doubt
Hope everyone is doing well. I miss the good old days for sure .
