hi guys, first time poster here. i have a 95 mystique i have had as my daily driver for about 4 years. i have put 70,000 on it and it is at 150,000 miles now. i gave it a good detailing and went to lunch fine came back 2 hours to leave work and it wouldnt start, but cranked day, i have checked numerous things and cant seem to figure it out, including making sure the engine compartment was dry.( so you know it did not have the wire harness recall done and alot of the insulation in the engine compartment is fraying so it could be part of the cause) i have checked for fuel, spark air and compression and it still wont start. checked fuel filter, fuel pump, all fuses, spark plugs and more.....Could the crankshaft sensor be intermittently failing?????
it did however start one morning after unplugging the mass airflow senor but it died and wouldnt start again as soon as i got it out of the parking space. im am about done with her and dont want to let her go but the blue book is only 300 dollars so im not willing to put that much work into it. i need to get on on the road or get it gone. either option is open. car is manual 5 spd, and located in maryland.
