SVOFANATIC
As I will soon tune my 3L I figure this is the better place for this.
I'm curious where I need to locate my Wide band AFR sensor in my exhaust. I know on all vehicles that you need to put it 6-12in from any type of a disruption in flow BUT you all have a single tail pipe which means you can put it before the resonator...... My car has True Duals so do I just put it after the X pipe? So that way I know the front and rear banks have mixed creating an equal flow? I don't wanna run two sensors and putting it at the header before the X means that the wide band will only be reading what 1 bank is doing.
Thanks for any help
Justin
Thanks for any help
Justin
