W WyomingGL CEG'er Joined Dec 24, 2008 Messages 72 Location Cheyenne, WY Mar 17, 2009 #1 I am going to be installing my new water pump.....I heard somewhere NOT to use sealer with these.....but the instructions say to use it. what should I do?
Z zorrex Enjoys the Abuse Joined Mar 26, 2007 Messages 11,840 Location South Amherst, MA Mar 17, 2009 #2 You mean between the block and the pump?
W WyomingGL CEG'er Joined Dec 24, 2008 Messages 72 Location Cheyenne, WY Mar 17, 2009 #3 zorrex said: You mean between the block and the pump? Click to expand... Yes..
Z zorrex Enjoys the Abuse Joined Mar 26, 2007 Messages 11,840 Location South Amherst, MA Mar 17, 2009 #4 I'm 90% sure that we put some sort of sealer between the pump and gasket, and then between the gasket and block, but I'm not absolutely positive...
S striker2 Official CEG Vendor Joined Mar 15, 2004 Messages 7,903 Location Arvada, CO Mar 17, 2009 #5 no sealer necessary, just make sure the gasket surface is clean of all old gasket material and is dry.
M mcgarvey Veteran CEG'er Joined Jul 24, 2005 Messages 523 Location South Jersey Mar 18, 2009 #6 98+ don't even use a gasket. Just a black o-ring.
W WyomingGL CEG'er Joined Dec 24, 2008 Messages 72 Location Cheyenne, WY Mar 20, 2009 #7 Used a THIN layer of Silicone Sealer. Seems to be ok. striker2 PM sent on another issue.
