Barge
If you have an EBC you should be able to.
I have a .9 bar spring and run 24 psi w/o problem
Ryan, are you sure your having WG issues? Sounds more like your losing boost up top for another reason. Maybe boost leak, since your turbo should be able to hold that no problem. Have your pressure tested your system at all? Is the boost going to zero or just dropping slightly and holding? Still doesn't hurt to pressure the system for the amount of boost you want to run, plus maybe 2psi. You would be suprised were leaks can creap. Also check to make sure your BOV is sealing properly. That flutter we talked about sounded more like a leak to me or to strong a spring, which I doubt. I would look there first.
Checking for leaks would be good Ryan.
As mentioned you want the spring in the wastegate to be the LOWEST boost you want and then add higher boost with the controller.
Also, I wouldn't waste your money on the AMS-1000, the AMS-500 is all you need. I've looked at them close and the 500 is all I and you would need.
There is a sponsor over at turbomustangs.com or turboforums.com that has them for a good deal, let me know if you want that contact info.
-J
Yeah get me his info that would be great man, thanks.
Damn Joey you are quick, I got the spring last night. But before install I will be doing a pressure check, any shop that works on turbo cars should be able to do a pressure test right?
